JTC
PFM Villager...
Just floating an idea. I have a Rega P25, which I bought when I basically downgraded from my previous Notts Analogue setup.
It's fitted with RB300 and AT33 PTG Anniversary cartridge, but until recently has had little use. Mainly because, with young boys, the danger of damage and lack of time to listen prevented it. So I concentrated on my streaming setup.
The boys are now old enough to leave well alone, and I'm intrigued to get back into the vinyl. Not in a major way - as I sold a good proportion of my vinyl with no regrets - but enough so that I can again enjoy the records that remain.
How much would I have to spend to usefully improve upon the P25? I could keep the arm if need be, and would definitely keep the cartridge. Phono stage is currently a Dyna P75, but could well end up being the internal one in a MyTek Brooklyn Pre/Dac, so I'd liberate a few bob from the P75 to put into the funds...
I've had LP12s in the past - fun, arguably at least as good if not a little better than the P25, but currently over-priced for the improvement (if any) you'd get. Clearaudio - a bit analytical - and the NA deck (stunning, but a bit on the big side).
In the time I've paid no heed of vinyl and turntables, surely there must be something else that applies modern tech that can blow away the old fruit boxen and the older Regas. Is the answer 'newer Regas', or something else?
thanks.
thanks.
