Interestingly, putting your ear next to the woofer (at any reasonably loud level) always sounds less painful than listening in the nearfield to a tweeter. Go figure ...The high frequencies are not the problem, it's the pile driving beat that rocks the house,which cause problems. I don't think there's an SPL weighting for that.
Because the woofer is much larger than your ear and is a distributed source. Up close your ear will be intercepting less than 1% of the output of a 12 inch. The tweeter is comparable to your earInterestingly, putting your ear next to the woofer (at any reasonably loud level) always sounds less painful than listening in the nearfield to a tweeter. Go figure ...
Really?!! My SPL meter and calibrated microphone would disagree vehemently with you.Because the woofer is much larger than your ear and is a distributed source. Up close your ear will be intercepting less than 1% of the output of a 12 inch. The tweeter is comparable to your ear
Look at it as power density in W/m2.Really?!! My SPL meter and calibrated microphone would disagree vehemently with you.
