What are usually called ham slicers (knives) make slicing by hand a reasonably simple task. You need a good cutting board and room enough as well though. And a steel if you haven't one already.
Machine? Just think of the ball-ache of cleaning it after less than 5 minutes use.
Ease of cleaning seems to be a complaint in some of the Amazon reviews. I guess you’re right that 5 mins cutting and 15 mins cleaning could get tedious
I have a Krups slicer that works quite well for meats and vegetables, but it's a pain to set up, and to clean. It's at least 25 years old, and is always a little "sticky" to the touch.
We have a Siemens, we purchased it purely for cutting hams very thinly, which it does very well. Cleaning is quite easy and it has lasted many years of light use.
Price wise I'm a bit hazy but at a guess it was no more than €50 back then.
