hi fi and home cinema integation?
Discussion in 'audio' started by diybry, Jun 27, 2020.
  1. diybry
    diybry pfm Member
    Hi,
    I have a pretty standard 2 channel setup, Linn and computer audio into Naim 32.5/250 and Kef speakers.
    I'm looking at buying a projector based home cinema system, however it seems logical to use the existing system as the front stereo part of a 5:1 system, but I cannot find much on the 'net regarding this.
    Do any Fishies have any experience/advice please?
    torstoi likes this.
  2. Amber Audio
    Amber Audio This is the Day
    Yeah, a lot of amps have an AV bypass input option aka Unity Gain, with the 32.5 you will need to use Aux and set the volume manually to the same level you used to set the 5.1 system up using the mic and room measuring software or old skool sound pressure meter/tape measure/test tones. So it's easy to remember set the Naim to 9 or 12 o clock, then when it’s movie time put the Naim to Aux and set the volume.
    Some info with pics here
    https://www.roydaudio.org/articles/improving-stereo-performance-surround-sound-setup-part-2/
  3. StephenB
    StephenB Pointy birds...........
    If your budget stretches a sennheiser ambeo soundbar
    there were a lot of issues when first released, but my replacement has been fine over last 5 months
    luckily my main speakers are best well away from wall, this allows the angled speakers on end of soundbar to navigate around them for a pretty convincing effect using the calibration mic
    Del monaco likes this.
  4. diybry
    diybry pfm Member
    Yikes! £2k soundbar!! I don't think that is within the planned budget! I imagine it sounds great though.
    Thanks for the Royd audio link, it looks like input to the 32.5 is the favoured option. I'll have to do some research into projectors next, all I look at seem to have built in amplification, which I don't need, am I looking at the wrong thing?
  5. Amber Audio
    Depends on budget, massive oversimplification, LCD orDLP are the common technologies, some get rainbows and headaches with DLP so if buying blind :D go LCD.
    Most have a basic speaker in cos they double as business machines. Epson do a lot of good value LCD PJ’s. Check the warranty and if it covers the bulb too and for how long/how many hours, they have counters built in that a tech can check.
    https://www.avforums.com/articles/what-s-the-best-projector-for-you.11774
  6. diybry
    diybry pfm Member
    Most probably will buy blind, so LCD it will be....Interesting link, I'm not interested in 3D. native 4k sounds unnecessary. Probably will go for a projector around the £500 mark plus a 5.1 decoder/amp and centre/rear speakers.
    Laser projectors sound like the dogs .... but far far too expensive yet. I an imagine they'll be cheap as chips in a few years!
  7. Amber Audio
    Something like the Epson TW650 should suit
    https://www.richersounds.com/tv-projectors/projectors/epson-eh-tw650.html
    An amp from Denon/Yamaha/Marantz - £500 ish
    If you want a slimline amp then Marantz 1609/1710 would be one of very few choices - I have the 1608 and it's great
    Normal size amps like a Denon x2600H will be on offer as new x2700H model is just out
    Yammy there are usually deals at Peter Tyson/7Oaks - RX880 or the 680 for £399
    https://www.sevenoakssoundandvision.co.uk/p-9920648-yamaha-rx-a680-black-av-receiver.aspx
    Try and get a Centre speaker to match your front voicing (not always possible) rears don't matter so much Dipole or Tripole diffuse the sound - Monitor Audio do a lot so you can get deals ex dem/old stock e.g. Bronze centre + 2 x Rear Fx = £300 at 7oaks
    https://www.sevenoakssoundandvision...onze-fx-black-oak-surround-speakers-pair.aspx
    Maybe look at a Sub - BK Electrics (eBay outlet store) or Rel (Richer Sounds/7oaks/Peter T) - BK Gemini or Rel T Zero around £200
    http://rover.ebay.com/rover/1/710-5...0001&campid=5338728743&icep_item=114277351242
    https://petertyson.co.uk/open-box-rel-tzero-subwoofer-black-ref-630861
  8. diybry
    diybry pfm Member
  9. chartz
    chartz If it’s broke fix it!
    Oh dear. I will never mix TV and hi-fi.
    Two completely different and incompatible things as far as I’m concerned.
    A total heresy. :)
    I fundamentally hate those 5.1 thingies. Completely artificial. And that silly central speaker... really?
    My TV is simply stereo and it is enough.
  10. Amber Audio
    Yeah those Kef Eggs are great, should match pretty well with the R500 as they all use the Uni Q driver system, you can always upgrade to the matching R2c later.
  11. Amber Audio
    Very constructive and helpful post
    Nytechy, Hoopsontoast and booja30 like this.
  12. chartz
    Just a point of view. I don’t see the point that’s it.
    Sorry.
  13. jackbarron
    jackbarron Chelsea, London
    Life was easy when Linn did their Classic Movie system and we all lived in DVD land. You had hi-fi, AV, TV and a tuner, all in one box and it sounded great.
    Jack
  14. HabUK
    HabUK pfm Member
    You just need a amp with pre outs to feed to your HiFi amp to power your two main speakers, this is how I've done it, works tremendously.
  15. Amber Audio
    Each to their own, my grandmother couldn't see the point of an expensive colour TV - and she liked to watch Pot Black :)
    A proper integrated AV/Hi Fi system is a fantastic experience, if it's done right, admittedly of most interest to hifi folk that are movies fans
  16. diybry
    diybry pfm Member
    I agree that the two systems have fundamentally different roles, however only the front speakers are shared components.
  17. diybry
    diybry pfm Member
    What amp are you using?
  18. HabUK
    HabUK pfm Member
    Home Cinema? Yamaha DSP-AX763, it's a few years old now, that feeds my Rotel amp that's for my hi-fi
  19. Suffolk Tony
    Suffolk Tony Aim low, achieve your goals, avoid disappointment.
    Of great interest if you enjoy some of the great surround sound mixes from the likes of Steven Wilson & Alan Parsons. Some superb music concerts on Blu-ray/DVD to enjoy too. With systems like Dirac around to optimise multichannel sound, you've got a whole other dimension available for music reproduction.
  20. wd40addict
    wd40addict pfm Member
    I have 72/Hicap/160 and to avoid needing to play around manually and using up another input om the 72 I built a switchbox using a reed relay. When I turn my Yamaha DSP-E800 decoder on it automatically switches the decoder output direct into the NAP. If the decoder is off then the 72 is connected.
    The Yamaha also has analogue 6 channel input in addition to Dolby/DTS which has come in very handy lately for playing SQ Quadraphonic LP's :)
    Projector is a now 10 year old Optoma DLP.
    You do not necessarily need a centre speaker, I just set the decoder to centre off and the centre signal is then routed equally to the two front speakers giving a phantom centre.
    When the Naim replaced my previous Audiolab setup for movies, to use the well worn forum cliche, my wife (who's more into movies than stereo) commented on the improvement!
