Mynamemynaim
38yrs a Naim owner
So I want to wire my ALWSRs in to my Naim 72 in a more permanent and neat way than I had them before (though I was happy with the previous sound improvement)
I just want to run the 4 regs to the two gain and two time alignment boards (these are Ryan Sound Labs boards) Should I just remove the 4 positive pins that I have marked with a red dot in the picture, and solder power to the back of the boards?
I guess this will bypass the speaker relay, so I will probably have problems with "thump" if done this way?
do I have to worry about the 27ohm resistor (that Ive read about but cannot find on the motherboard?)
Lastly ...what about the illuminated Naim logo? I guess if I want to keep it, I will have to make provision to power that from somewhere too?
Ohh and almost forgot...I have created a common bar between the main power in return and the case return (copper wire seen in the picture)..so that I can easily strap the ALWSRs returns to it....will i get problems with an "earth loop" doing that (bearing in mind I have two power supply's coming in and I'm using the Mr Tibbs return mod
In other words....those that have done this before / have experience of this...what's the best way to proceed please??
[/url]IMG_20210822_164440~2 by rock solid, on Flickr
[/url]2021-08-22_06-03-09 by rock solid, on Flickr
