help with cloning
Discussion in 'd.i.y.' started by philiphifi, Sep 12, 2019.
  1. philiphifi
    philiphifi pfm Member
    Dear all,
    i am thinking of cloning a kondo neiro amp. There are circuit diagrams etc but i need some help with it + details with people who can manufacture a decent chassis.
    Please let me know if you are able to help
    thank you
    Philip
  2. Arkless Electronics
    Unless you can get the proper output transformers it's a non starter!
  3. philiphifi
    i can source a decent output transformer. (hopefully anyway)
  4. Guest432
    Guest432 Guest
    Tango, Tamura or Hashimoto are all good alternatives.
  5. Vinny
    Vinny pfm Member
    Curiosity, having just checked online and found that one sold second-hand for around £9K, 2 years ago, what sort of money would you expect to spend to make a respectable clone?
  6. stevec67
    stevec67 pfm Member
    What's so special about the OP transformers? There's a bit of talk on the web about "special windings", is this the case?
  7. Arkless Electronics
    I'm not au fait with the specific ones used here but the output transformers are the most crucial part of any valve amplifier and have a massive effect on everything basically..
    IMO you cannot build a clone of a valve amp unless you can get the original output transformers... anything else would be "in the style of" but not the real thing and would not sound the same... maybe better, or worse or different but not the same!
  8. stevec67
    stevec67 pfm Member
    OK, thanks. So the anecdotes I have heard of people reusing mains trafos as OP trafos for audio are either fairy tales or going to sound pretty dismal, are they?
  9. Arkless Electronics
    It can be done but they would not be of hi fi quality and probably only good enough for a public address system, a "Tannoy" in a railway station or similar!
    High quality OPT's are made with special grain oriented silicon steel lamination's and with multi section interleaved windings. Without this they would have high distortion and no treble beyond maybe 8KHz! The high phase shifts would mean that little or no negative feedback could be applied without the amp going unstable.
    The design of really high quality OPT's for valve amps is often regarded as somewhat of a "black art"...
    davidsrsb likes this.
  10. Barrymagrec
    Barrymagrec pfm Member
    The improved magnetic materials developed during the war were much of the secret behind the various genuine hi fi amplifiers developed just afterwards. Williamson, Quad, Leak and so on.
  11. Dowser
    The OP transformers in my DIY valve hybrid SEs cost over AU$1000 a pair...over 20 years ago! This was easily over half the cost to build them. At the time there was one recommended guy in Australia to get them from.
  12. davidsrsb
    davidsrsb pfm Member
    That proportion is about right, spend the money on a good transformer, not the front panel
  13. Dowser
    Haha - you haven’t seen my mono blocs - money did not go on cosmetics :)
  14. coltrane
    coltrane electrobaroCKjazzer
    without going too deep into the matter, yes, the real secret of the Kondo/AN O/P transformers is that, the winding, which is quite intricate, not just reeling the wire on a metal laminate. this is mainly the reason why the circuit diagrams of the AN amps are readily available, and why PQ decided not to keep them secret (knowing clones would inevitably appear anyway)
