DPA_SERVICE
Your PDM2 was manufactured at DPA Digital in September 1992, unit number 7, using redundant Deltec cases.
Probably the case work is the glossy powder coat finish, which looks good, but suffered too many rejects, thus the spatter finish took over.
Know nothing of the Jitterbug, but I would imagine that the Deltran modification could be fitted to the DT40. Do you have any technical skills?
According to Rob Watts, the dac does most of the work, the CD just spins the disc.
Your PDM2 may need it's selector switch replacing; the tell tale sign that it is aging is a crackling noise through your speakers. A similar sounding fault could indicate that the optical transmitters are also reaching the end of their life cycle. The switch is cheap and good quality replacements for the optical components can be sourced from Digikey.
As for the Toshiba? The Dac will probably work with it, but just treat it as a suped up CD player. Demo it first before buying and never trust the opinion of salesmen or Audio Reviewers. Your own hearing is much more reliable.
