Help! To change BNC phono sockets on a 72 to RCA
Discussion in 'd.i.y.' started by Nye Samuel, Mar 14, 2023.
  1. Nye Samuel
    Nye Samuel Herr Katze
    I can't do it...I don't want to use adapters.
    Can anyone here do it? I will provide the RCA sockets and pay all the postage and recompense you for your time.
    I am in Biggleswade in Bedfordshire.
    With best wishes
    Nye
    PhilDick likes this.
  2. laverda
    laverda pfm Member
    Nye, Send it, it will be done.
  3. Nye Samuel
    Thanks Graham...I will send you an email.
  4. wd40addict
    wd40addict pfm Member
    Make sure you use good quality sockets, I ended up doing this mod twice! The generic gold plated type I used first time round didn't make reliable contact. Second time round I used Cardas from hi-fi collective and these have been absolutely fine
    Mynamemynaim likes this.
  5. Nye Samuel
    I was planning to choose WBT...I will ask Laverda for his recommendation but thanks for the suggestion.
  6. laverda
    laverda pfm Member
    Don't buy the cheap so called quality 'unbranded' RCA's, but how do you know their shite, the only way is to buy and curse after.
    Cardas CTFA & WBT are good (soldered, gas tight connections) :)
  7. Nye Samuel
    I have bought a pair of Cardas CTFA RCA sockets....using RM Special Delivery...so hopefully they will arrive by the end of this week.
    wd40addict likes this.
  8. Mynamemynaim
    So glad you are getting your RCA sockets fitted..
    You already know how good a 72 with RSL boards in sounds
    The final step is super regs for the boards and you really will have a giant killer....but enjoy for now:D
  9. Nye Samuel
    PM sent....please explain what you mean.
  10. laverda
    laverda pfm Member
    :rolleyes: really...
  11. Mynamemynaim
    @laverda
    Perhaps you can pop some in for him Graham while it's on the bench :D
