Having made a start on a home build HiCap replacement, I am in a quandary as to what capacitors to use as the smoothing caps.
I am starting with a dual 16v transformer so after rectification I should presumably be able to get around 30v. The hicap has dual 16000 uF caps (as the hicap use dual half wave rectifiers -if that is the right term).
What value should I start off using? This is an experimental project & first foray into homebuild.... so i dont want to go over the top & want to bring the project in if not for minimal outlay then for not too great an outlay!!! I intend to have half a dozen regs attached to it to power an 82 pre.
Is it necessary to provide as much as 30000 to 40000 uF as per the HiCap?
If so any suggestions for best VFM caps?
Is it worth stringing together say 8 or 10 4700uF caps?
For longevity what rating do the caps have to be? Would 35V caps be sufficient? The hicap has 63v caps but then if I remember correctly the transformer is providing a higher voltage than I have....
I dont mind experimenting but having checked some of the sites there are so many makes / sizes / prices of caps available, some guidance from people who have been there would be appreciated.....
Thanks in advance
Neale
Thanks in advance
Neale
