S-Man
StrivingON
I am looking for suggestions for a pair of passive speakers for siting behind my TV. The TV is in the corner and the speakers will fire out to the sides with sound reflected off the side walls in a modest attempt to get some stereo effect.
They will be driven by a "standard" analogue power amp.
Requirements:
~150mm wide or less
Absolutely no tendency to exaggerate sibilance
No boomy bass (sealed box or plugged port preferable to bass extension)
High SPLs not required
£200 max
Shortlist (so far):
Q Acoustics 2010i or 3010i
MA radius 90, 2nd hand
Requirements:
~150mm wide or less
£200 max
Shortlist (so far):
