HI Guys, My next post was about to be a tale of how (after a very hesitant start) my 1010 (bought Sept 2017) had sonically soared past my RSL'd naim 75 preamp and NAP 140.
Unfortunately it has now developed a fault...
anyone owning on e of these will know that the power button surround (normally) flashes when the button is pressed and then emits a loud click , at which point the flashing becomes a constant light and music will be heard from any source selected if the volume is up.
At the moment this works as normal so long as no input is selected - as soon as source is selected and volume turned up the power button will click intermittently every 3=4 seconds, effectively turning the music on /off every few seconds. My hi fi is doing a good Norman Collier impression but is unlistenable.
with my limited knowledge it seems the relay on the button is faulty but i have no idea otherwise. i have spoken to 5 ways hi fi in Birmingham who said it sounded problematic and that parts would be an issue...they didn't want to do it
So any suggestions Advice gratefully received partcularly for likely bods to repair it. just for info it was bought as NOS from USA and is in obvious (outwardly) pristine condition - i use an airlink transformer to convert to UK voltage... the sound it produces is pretty damn good so i would be loathe to abandon it at this early stage
many thanks for any help
Dave
Dave
