PeteM
Supreme being
The title says it all.
I have a Naxo 3-6 which produces less bass than our TV soundbar!
I realise I can adjust LF, MF and HF output separately by turning the preset pots on the PC board (photos below). Thoughtfully Naim have labelled them LF1, LF2 etc so I know which ones to tweak. Presumably they are in pairs for a six-pack setup (mine's tri-amp), so I just turn both LF pots equally? Which directions give more/less output? I might be answering my own questions here, but I'd like to be sure before I fiddle. The outputs have been altered by Witch Hat to give a vertical amp arrangement, presumably this makes no difference to the task in hand. It'll all be done with the Naxo un-powered out of the system of course.
Any advice gratefully received!
