Musicraft
Trade: Musicraft
The Absolute Sound reviews Hegel's H160 amp/DAC
http://www.theabsolutesound.com/articles/hegel-h160-integrated-amplifier-1/
https://www.eisa.eu/awards/hi-fi/5/european-amplifier-2015-2016.html#award
EISA Award - H160 European Amplifier of 2015-2016
https://www.youtube.com/watch?v=i7yr-GUJJ5s EISA - H160 YouTube video
http://www.hegel.com/images/reviews/H160hifiplusuk.pdf
Hi-Fi Plus H160 review
http://www.hegel.com/images/reviews/H160hifichoiceuk.pdf
Hi-Fi Choice H160 review
https://www.youtube.com/watch?v=FpEBxoOLH_c
SoundStage! InSight -- Hegel's H160 Integrated Amplifier-DAC April 2015 YouTube video
http://www.soundstageaccess.com/index.php/equipment-reviews/637-hegel-music-systems-h160-integrated-amplifier-dac
Soundstage Access H160 review
http://www.stereophile.com/content/hegel-music-systems-h160-integrated-amplifier
Stereophile H160 review
http://www.enjoythemusic.com/magazine/equipment/0915/Hegel_H160_Review.htm
Enjoy The Music H160 review
Lydogbilde - Hegel's H160 "Amplifier of the Year" award
Lydogbilde - Hegel H160 "Amplifier of the Year" award
Hegel H160, Hegel's H30 and ATC's curved SCM40 passive monitors at Musicraft
Hegel H160 amp/DAC, Raidho Acoustics X-1 loudspeakers and two JL Audio E-110 subwoofers at Musicraft
H160 amp/DAC
H160 amp/DAC
H160 amp/DAC
H160 amp/DAC
H160 amp/DAC
H160 amp/DAC
The H160 amplifier has one purpose, and one purpose only - to allow you to connect whatever device you want and make it sound as good as it possibly can. First of all, we designed an integrated amplifier with a broader set of connections than any other amplifier on the market, in this category. There is a wide variety of connections, varying from classic balanced and unbalanced analog connections, to Home Theatre integration and onwards to various digital inputs. You can also stream wireless music to it from devices with Apple AirPlay or DLNA. Secondly, we realized that not all the devices you choose to connect are designed to be high-end music performers. This meant we had to develop a range of unique technologies and implementations to make certain that your phone, tablet or CD-player could reach its fullest potential. The H160 incorporates technology that "repairs" some of the damaged caused by a low quality source.
Finally, we integrated the new with the classic, and included our award-winning and worldwide patent holding amplifier technology, the SoundEngine. This amplifier design completely turns ordinary amplifier designs upside down. The result is a purer and smoother sound with low distortion, as well as ultra dynamic bass due to a high damping factor. And yes, you can also use your headphones, and it uses up to 60% less power than an ordinary amplifier. So, what are you standing there thinking about?
Damping factor -
Technically - it is a term describing the difference between the output impedance of the amplifier and the load impedance of the loudspeaker.
Practically - It will determine the stability of the amplifier. It needs to stop the “return kick” of current from the loudspeaker or it will be knocked out of balance.
Eeeuhhmm? - Sonically, a higher damping factor means better bass control. Lower damping factor means fluffy bass.
Standard - The industry average is 60-80. Hegel is 1000-4000. That is what makes Hegel so tight and dynamic.
Technical Details
Power output spk: 150 w/pc into 8 Ohms, 250 w/pc into 4 Ohms
Power output hp: 270 mw/pc into 4 Ohms
Analog inputs: 1 balanced (XLR), 1 unbalanced (RCA), 1 home theatre
Analog outputs: 1 fixed line level (RCA), 1 variable line level (RCA)
Digital inputs: 1 coaxial, 3 optical, 1 USB, 1 ethernet (RJ45)
Headphone output: 6,3 mm Jack (front)
Frequency response: 5Hz-100kHz
Signal-to-noise ratio: More than 100dB
Crosstalk: Less than -100dB
Distortion: 0.005% @ 50W 8 Ohms 1kHz
Intermodulation: Less than 0.01% (19kHz + 20kHz)
Damping factor: More than 1000 (main power output stage)
Dimensions/weight: 12cm x 43cm x 41cm (HxWxD)/19kg (shipping)
Dimensions/weight: 4,7" x 16.93" x 16.15" (HxBxD)/42lbs (shipping)
RRP £2350
Hegel SoundEngine Technology
http://www.hegel.com/technology/soundengine
https://www.facebook.com/hegelmusic/videos/1557873347773276/?video_source=pages_finch_thumbnail_video
Hegel SoundEngine Technology video with Founder and technical director of Hegel, Bent Holter
***** https://www.facebook.com/MusicraftUK *****
Rick @ Musicraft
