Musicraft
Trade: Musicraft
Hegel's eagerly awaited H360 amp/DAC is now on it's way Musicraft would like to share the journey of our Hegel H360 amp/DAC stock from Hegel Music Systems
Oslo, Norway 27/08/2015 17:52 Export Scan
27/08/2015 17:52 Origin Scan
27/08/2015 15:30 Collection Scan
Norway 25/08/2015 9:17 Order Processed: Ready for the courier
"Yet, in summary I want to change my sporting analogy. In Hegel combining its extensive know-how around lowering distortion, eradicating noise and preserving phase and transient timing, the H360 is achieving something that is much greater than the sum of the beneficial parts. It’s the effect of watching a truly talented footballer like Messi or Cantona on the ball – time slows down and skill just expresses itself beautifully. Music I know extremely well is refreshed and the artist’s intent becomes clearer. It’s not a matter of extra detail revealed, it’s just effortless, unhampered communication. The sheer cleanliness of the H360’s delivery means I’m better able to understand and enjoy my music"
“The integrated amplifier is coming of age again, and in the H360 Hegel has created a new reference product in its range that looks to be creating a whole new benchmark performance for others to try their best to match” Chris Ward Hi-Fi Choice (UK) - September 2015
H360 amp/DAC
H360 amp/DAC
H360 amp/DAC
H360 amp/DAC
H360 amp/DAC
H360 amp/DAC
H360 amp/DAC
Hegel H360 is a giant among integrated amplifiers. With 250 watts per channel into 8 ohms and a damping factor of more than 4000, it will control virtually any loudspeaker on the market. Thanks to the patented SoundEngine technology, this beast of an amplifier combines power, dynamics, finesse and musicality like no other integrated amp on the market. The connectivity is more of a bonus... There are balanced and unbalanced analog inputs. There is a Home Theatre bypass. There are optical and coaxial digital inputs, as well as a USB input for any signal up to DSD128... And, yes - it is also a streamer. Need we say more?
The core of everything Hegel is sound quality, and the H360 is no exception. The obvious benefit of the H360 is easy to see - power. It can deliver 2 x 250 watts per channel into 8 Ohms, and is stable even in lower impedances. Furthermore, the damping factor of more than 4000 makes certain it can take control over even the most demanding loudspeakers. The H360 will always play with great authority and ease.
Rarely is such power combined with finesse. However, specially designed power supplies driving precision volume attenuators contributes to an extremely low noise floor. Hand matching near perfect transistor pairs in the input stage reduces harmonic distortion. Our patented SoundEngine technology reduces over all distortion, and especially cross-over distortion. Our designers understand how transistors work, down to the atomic level, and have used all this knowledge in designing the H360.
The H360 incorporates a high quality DAC, using Hegel’s proprietary re-clocking. The benefit of this is that we can make everyday sources sound really good. Sources like a phone or a computer. This is why we have also included functionality like Apple AirPlay and DLNA streaming. There is also a reference class USB input, supporting all formats including native DSD64 and DSD128.
Technical Details
- Power output spk: 250 w/pc into 8 Ohms, 420 w/pc into 4 Ohms
- Analog inputs: 1 balanced (XLR), 1 unbalanced (RCA), 1 home theatre
- Analog outputs: 1 fixed line level (RCA), 1 variable line level (RCA)
- Digital inputs: 1 coaxial, 3 optical, 1 USB, 1 ethernet (RJ45)
- Digital outputs: 1 coaxial (from digital inputs only)
- Control input: 3,5 mm IR-Jack (rear)
- Frequency response: 5Hz-180kHz
- Signal-to-noise ratio: More than 100dB
- Crosstalk: Less than -100dB
- Damping factor: More than 4000 (main power output stage)
- Dimensions: 12cm (15cm w/feet) x 43cm x 43cm (HxWxD)
- Weight: 20,5kg (net), 24kg (shipping)
- Dimensions US: 4.72” (5.9” w/feet) x 16.93” x 16.93” (HxBxD)
- Weight US: 45,2lbs (net), 53lbs (shipping)
RRP £3400
Hegel SoundEngine Technology
http://www.hegel.com/technology/soundengine
https://www.facebook.com/hegelmusic/videos/1557873347773276/?video_source=pages_finch_thumbnail_video
Hegel SoundEngine Technology video with Founder and technical director of Hegel, Bent Holter
***** https://www.facebook.com/MusicraftUK *****
Rick @ Musicraft
H360 amp/DAC
H360 amp/DAC
H360 amp/DAC
H360 amp/DAC
H360 amp/DAC
H360 amp/DAC
H360 amp/DAC
Technical Details
RRP £3400
Rick @ Musicraft
