Hegel
H30 mono/stereo power amplifier - The Absolute Sound
2015 Editors’ Choice: Power Amps $10,000 - $20,000
http://www.theabsolutesound.com/articles/2015-editors-choice-power-amps-10000-20000/
http://www.theabsolutesound.com/articles/hegel-h30-reference-power-amplifier-tas-223/
Hegel H30 mono/stereo power amplifier
Hegel H30 mono/stereo power amplifier & Hegel P30 pre amplifier
With a power rating of more than 1,1 kW in 8 ohms it is on the verge of being easier to measure the
H30 in horsepower. The massive
H30 mono power amplifiers from Hegel play any loudspeaker in the world with ease and authority. The
H30 is our best power amplifier ever, and is definitely a combatant for being the best power amplifier in the world. The
H30 is developed as a mono block, but there is also the possibility to use it as a stereo power amplifier to start with if you are on a budget. Progress is a one way street and so for our power amplifiers. The
H30 is using a new and improved version of the patented Hegel
SoundEngine amplifier technology. This further reduce all types of distortion. In addition to the improve
SoundEngine we are also using the highest possible level of the Hegel FET-technology in the input stage and the voltage gain stage. This technology reduce a very specific type of distortion called Harmonic Distortion. This particular type of distortion causes what many people call "transistor sound", and this is therefore dramatically reduced in the
H30. It will simply let the music reach you in a different way than what you have ever experienced before.
Normally, when you compare a less powerful amplifier with a more powerful amplifier, the most powerful will have a more potent bass, more attack and more "SLAM" than the less powerful one. This is how it works up to a certain point. The Hegel
H30 is beyond this point, and all of a sudden the differences become different. The
H30 will simply play with a completely undisputed control, regardless of the loudspeakers. The bass is tremendously deep, but not dominating. The level of detail in the high frequencies are unheard of, but never overbearing. Usually a demo of the H30 and P30 combination ends with clapping hands and a whispering wooooow...
So what sets the
H30 apart from the H4SE? There are several technical differences. As a mono power amplifier, the
H30 has a fully balanced output stage which reduces distortion and cancel out distortion. Further more, the
H30 has a much more advanced input stage and voltage gain stage. Both the H4SE and the
H30 uses hand matched transistors, but only the
H30 uses the special combination of JFET and MOS-FET transistors. This further reduces higher order harmonic distortion in the
H30. The third big difference between the two is
H30's output transistors. These are of higher quality, with less distortion, than the ones in the H4SE. In addition to this, the use of dual transformers in the
H30, reduces mechanical noise. The higher budget also allow the use of better parts throughout the
H30.
Technical Details
- Output power: More than 1100 W in 8 ohms
- Miniumum load impedance: 1 ohm load
- Inputs: RCA unbalanced and XLR balanced
- Speaker outputs: Two pairs of heavy duty gold plated terminals
- Input impedance: Balanced 20kohm, unbalanced 10kohm
- Signal to noise ratio: More than 100dB
- Crosstalk: Less than -100dB
- Distortion: Less than 0.003 % at 100W i 8 ohm
- Intermodulation: Less than 0.01 % (19kHz + 20kHz)
- Damping factor: More than 500
- Power supply: 2000VA dual mono, 270 000uF capacitors
- Output stage: 56 pcs 15A 200W high speed, Ultra low distortion bipolar transistors
- Power consumption: 120W in idle mode, 30 watt in ECO mode
- Dimensions/weight: 21cm x 43cm x 55cm (HxWxD), weight 45kg
- Dimensions/weight US: 8.3" x 17" x 21.6" (HxWxD), weight 99 lbs
RRP £10,000
http://www.hegel.com/products/power/h30#prettyPhoto
Hegel SoundEngine Technology
http://www.hegel.com/technology/soundengine
https://www.facebook.com/MusicraftUK *****
Rick @ Musicraft
