RichardH
Bodging pleb
Posted this as I started having a private message conversation with Quickie, but thought it might be of more general interest.
I'm building one of Les's dual mono power amps, and (being me) decided to do it the hard way - built the PCBs myself, and also the case. See "Should I spray" thread for progress on that front, but the case is looking good - painted black and ready to roll.
There have been a couple of comments re the Naim power amps not being sufficiently cooled (and I must admit, my 250 gets warm just on standby). As my case is basically a copy of a full width Naim case, I've started wondering whether I ought to add some more cooling, and if so, what and where.
Easiest thing would to be to run some heatsinking comb section down the sides of the amp, I guess, though most of it seems to be the wrong dimensions to suit. However, that would make the amp wider, and a bit of a joggle to get into the rack.
Another thought I had was to attach a heatsink to the alu heatsink brackets the modules sit on, within the case. This would mean bringing the modules closer together to allow space for the heatsink, and also I'd need to drill some holes in to top of the case to allow hot air to escape.
This brings me on to another point. My amp will contain a big fat transformer, 2 pairs of caps, 2 NCC modules and a soft start module (SSM). My case doesn't have the double skinned front like Les's ones, so I can't easily bolt the SSM to the front as per Les's layout - unless I use the sticky plastic pillar things - I wonder if they're man enough for the job though. I thought it might work if the SSM sat at the rear of the case between the NCC200 modules - short power cable runs and all - but I don't know if that will cause problems having that power circuitry so close to the NCC modules.
Any thoughts, anyone?
