Are they using plywood rather than MDF or chipboard?
I just noticed,
SHL5+ = 17.2kg each
SHL5+ XD = 15.8kg each
Does anybody know the physical changes that caused the reduced weight? I'm not sure if it's a similar pattern with the other models.
Maybe Alan Shaw is putting less of his collosal ego in the later models?
Have you weighed them?I just noticed,
SHL5+ = 17.2kg each
