I have tried the cheaper Hana EL on a 1200GR but not heard the ML, sorry.
The Cadenza is 50% more expensive than the ML, seems a bit of a mismatch? Why these 2 carts?
I have the Bronze on a 1200G, extremely pleased with how it sounds, did consider the Black but was worried about the top end reading up on them both, plus I got offered a great deal on one, it is one of those HiFi purchases that delivers more than you expect. I have tried the cheaper Hana EL on a 1200GR but not heard the ML, sorry.
Might be worth posting your TT/Arm/Stage and current cart. What carts have you had/liked/disliked.
Good all round cart, when it came out 5 years back under £300 a bargain, now at £400 still good value. Summed up I'd say safe/balanced. Preferred it to 2M Red and Black/Goldring Eroica LX/OC9II but not to an AT33PTG. Will also depend on phono stage too obvs.Sorry Gus,
what is your opinion about the Hana EL?
Cheers.
Mauro
Ouch. In that case I’d buy the ML, you don’t see much/any negative stuff written about it, you can get the Bronze fixed or trade to something when the ML is near it’s end.current cartridge is a cadenza bronze.audio technica at-1010 and sony tts-8000 tt. phono stage is a paradise.
previous cartridges are kontrapunkt b,at-art7,denon 103 sa,decca c4e.
my question comes from making one too many vta adjustments and brushing my hand against the canterliver as i pulled it away. the result was a bent cantilever. i have no complaints with the bronze,the trade in scheme or the repair is one option,the other is to try something different and repair the bronze at a later date. hence my thread.
Ouch , so sorry to hear thatcurrent cartridge is a cadenza bronze.audio technica at-1010 and sony tts-8000 tt. phono stage is a paradise.
Cheers I’ll keep that in mind, a bit of a ways off looking at a different stage, it's on the long term plan though.@Amber Audio Guy from pure sound is an AuroraSound distributor , I'm certain he would sort Vida home demo for you
