Guidance needed - resistor across switch legs (phantom power, racking audio module)
jon l
I want to add 48v phantom power to an audio input module from an old mixing desk. I know little about what I am doing but there is straightforward info on web, plus I have in front of me example of similar prof. racked modules. With these, the on/off switch has a resistor across two of its legs, shown below
is this there for safeguard or something? I measure about 8kohm across the resistor in situ.
Thanks in advance!
A LED, probably. A mains neon needs about 4.7 x 10^4 ohms IIRC, a TFL of correct voltage none, 8k sounds right for a LED, dependent of course on supply voltage.
The colour code for that resistor says 8.2k +/- 5%.
^ and if that 8K2 resistor connects 48vdc as a supply through an LED to 0v that implies about 5.6mA -yep, I concur, right about where you'd power an LED indicator.
(As such it's a non-critical value BTW, anything 4k7-22k or more would do the job; larger value resistor = dimmer indicator)
