thing is, a 8 inch midbass will always be much better in the bass then a 6,5 inch. imo, 6,5 inch based speakers are toys and cannot ever be played loud: no matter how good the mid will be, bass will be compromised (distortion, imd, extension limited). id also say i like big mid sound, 6.5 inch mid will always sound “small”
while yes the 8 inch beams and is a compromise desing to make it play up to 2.5khz/3khz, its still much less compromised then asking a 6.5 inch midbass to do bass.
i wouldnt be surprised that from 160hz and up the dynaudio would be slightly more refined then the graham, but the bass on the graham will be undoubtly much better, can play louder, better extension, ect. for me bass is very important
and i also think 8 inch sound small for bass vs 10”. then you compare a 10” with a 15” and you tell me if its even worth mentioning the “bass” of a 6,5 inch woofer. so yeah, the confidence 20 priced at 12 000 euro is insanity beyond words
lets just say id buy the dynaudio contour 60 (2x 9 inch woofer) over the confidence 20 without a doubt
As for harbeth shl5+ vs graham ls59, ive had both and they are more similar sounding then not, i just prefered slightly the shl5+
