Martyn Miles
They seem to have fallen off the radar.
I’ve certainly not seen anything about it.
FWIW - A Celestion HF2000 supertweeter that's missing its perforated brass grille will be down on output from 5kHz-17kHz by as much as -3dB in places (I know this because I've measured it!). So, if you've got speakers with HF2000s that are missing their grilles and find the top end a bit reticent, buy and fit the brass grilles, they are a crucial design feature!
Does it "increase" HF output or only refocuses/changes the directivity?Interesting observation. The same is true of the T27 tweeter in the LS3/5a. The perforated metal grill increased HF output significantly and was also part of the design (as was the heavy Tygan material on the front cover).
Good question!Does it "increase" HF output or only refocuses/changes the directivity?
I can't remember where I read it, but apparently the perforated brass grille increases air pressure in the gap between the tweeter's diapragm and the grille. How this results in increased SPL I don't know as I'm not a physicist, something to do which changing the impedance coupling between the tweeter and the air in the room?
