Hi I am at the very early stages of learning the DIY side of things, so please go easy on me !
I have an Avondale Grad 1 pre with one of the inputs down on the black/left channel. I checked continuity from the RCA jack to where the wire is soldered to the board and there is a signal coming through from the meter but no audio signal ? So i resoldered this point and now i have a signal, but its much fainter than the other (healthy) channel ? Has anyone any ideas what has happened here and what i should be checking next to resolve it ?
I know this is prob a simply fix for most of you but not sure what to do.
Thanks all for the collective wisdom.
Si
Si
