Craigy
New Member
Hello all, it’s been a while.
I’d be grateful for some sound advice about converting my speakers from passive to active. There are a few options I could choose from, none of which I fully understand!!
At the moment I’m running the speakers with a Teddy Pardo Pr1 and Mb100 mono blocks, sounds great but the “Aktiv” thing is an itch I have to scratch.
Ideally I’d like to keep the teddy pre to use it with Aktiv power amps but I’m not entirely sure that would even work.
Also if I’m properly understanding the info on another forum, if I were to use Majik power amps, I would need 4 amps??
Not an option with my lack of shelf space.
Another option I’ve thought about is using Akurate 4200, a bit more expensive but a superior amp I’m told. Again I’m not sure how many of these I would need and if they would work with the teddy pre.
Added to all this there’s the issue of which Aktiv cards I will need, all a bit of a minefield to me I’m afraid
I’d appreciate any input (idiot proof advice would be helpful !!)
cheers
Craig
cheers
Craig
