droodzilla
It is getting a bit chilly.
Must. Not. Switch. The. Heating. On.
Well, max. temp. here in Norwich was 12 degrees this arvo, with a nasty northern wind. I'm deffo feeling cold, even though the thermometer says 20 inside. Turning the heating on in the middle of September is a bit rash though; it's extra pullover time (unless you're in the Cairngorms or thereabouts, I s'pose. Heavy but fairly brief showers all day adding to the chill.
We've been having some heating on for part of the day for a while now. Live north of Edinburgh, so not surprising. Here it depends on how sunny it is as the black slates on our roof get pretty hot when it is sunny. Since we're on the coast that does happen quite often. Mix of gas and electric and directly heat the rooms we are in. So a sort of 'part heat as needed' approach.
Currently 22°C in the kitchen and sat here in a 'T' shirt.
More insulation required???? I think we're further North than you...........
Regards
Richard
Very good video regarding the current price problems, particularly from Yanis Varoufakis
Also after that wanting to see if we can have solarPV. But need it checked as its an old house and the roof might not like that.
Technically, it's certainly possible. Batteries don't care where the charging energy comes from. The savings will be smaller, though, since you'd always be paying something.A related issue is possibly having a 'house battery' but I have no idea if that would make sense in the absence of SolarPV as a way to 'time shift' buying electric energy to a cheaper time at night, etc.
