[FS] Fully built two way floor standers
Discussion in 'd.i.y. classifieds' started by Adam N, Jul 11, 2020.
  1. Adam N
    Adam N pfm Member
    Up for sale is a recently completed project. Using the HiVi isodynamic (ribbon) tweeters and Seas Er18rnx prestige 6.5" bass drivers. Crossovers use high quality capacitors and air core inductors. Based loosely on the Zaph SR71 and Starling designs.
    CNC machined metal feet each about 7kg, and with grub screws at the back so you can adjust the angle the speakers incline. Designed for a listening position of approximately 2m ~ 2.5m and elevation of 1m.
    Cabinets are CNC valchromat and white melamine faced plywood baffles, assembled and finished. Cabinets are ported and produce prodigious amounts of bass. If you like ribbon tweeters you will probably like the balance of detail and resolution these give without being too analytical.
    21cm wide
    18cm deep
    76cm high
    Amplification: 25 W – 100 W per channel
    Long term power handling: 80 W
    Sensitivity: 85 dB
    Nominal impedance: 8 ohms
    More than the sum of its parts and near double the cost to make as I'm asking. Too many projects mean these have to go.
    Price is firm £575 collected Oxfordshire
  2. JimmyB
    JimmyB pfm Member
    Those are very smart, that Valchromat is very nice.
    Adam N likes this.
  3. Adam N
    Adam N pfm Member
    Would consider a trade for a Naim NAP 200
  4. szczemirek
    szczemirek Mirek
    They are looking brilliant.
    Adam N likes this.
  5. Dan K
    Dan K pfm Member
    Those are some of the nicest looking modern speakers that I have seen. Fantastic work.
    When I saw the papyrus cones I thought you had used Sartori drivers. I've got some in my Sonabs at the moment, bloody lovely.
    GLWS
  6. Adam N
    Adam N pfm Member
    Thank you that's really very kind! The Satori are amazing drivers but these Seas ERNX ones are pretty damn good too.
  7. Lokidtc99
    Lokidtc99 What does this button do...?
    Do you have pictures?
  8. Adam N
    Adam N pfm Member
    They were in the original post but Google image links seem to break. Try these:
    booja30 likes this.
  9. fegs
    fegs pfm Member
    They look absolutely stunning!
    I'm not in the market for speakers but if I were .......
    Adam N likes this.
  10. Dan K
    Dan K pfm Member
    Adam, what caps and resistors have you used in the crossovers and where are the cab vents/ ports? Hopefully not out the bottom (floating wood floor)
    thanks
  11. Adam N
    Adam N pfm Member
    Hi Dan
    Ports are rear facing behind the tweeter. Caps are MKT Polyester Film and MOX resistors. Air core inductors.
    You can access the crossover if you remove the drivers and experiment with values as I have.
  12. Dan K
    Dan K pfm Member
    Interesting that you put the port so high up. Can you post a pic of the rear face
    Any details on the internal design? baffles/ bracing etc. Is this a 'live cab' design - looks like it sort of is
  13. Adam N
    Adam N pfm Member
    I'm not sure what you mean by the term "live cab design". The corners are braced, the panels are Valchromat and front baffle birch ply so a lot stiffer than conventional MDF. Dacron stuffing up to just below to rear port.
  14. russel
    russel ./_dazed_and_confused
    SEAS make nice drivers, very pleased with my Odin 3 speakers.
    Adam N likes this.
  15. Lokidtc99
    Ooh, they look lovely! Have you ever heard Neat's Elites (the originals without bulleted woofer, and with ribbon tweeter)? If so, how would you characterise these in comparison?
  16. Adam N
    Adam N pfm Member
    No I haven't heard those. If you liked dabbling you can alter the tweeters response by swapping the resistors on the crossover so you could tailor the sound. I've inverted them to get a better match to the mid bass. I'm not sure what I'd liken them to from a commercial speaker. Maybe the Monitor Audio studio series because of the tight bass and detail in the tweeters?
  17. Dan K
    Dan K pfm Member
    I meant a speaker cabinet design that uses the response/ resonances of the enclosure rather than one which sets out to make the cab as inert as possible. Snell J vs Avalon sort of thing.
    ie Avalons are made from angled, faceted + braced 3.5" thick birch ply and the Snells are pretty much a pair of drivers bolted into an acoustic guitar.
  18. Adam N
    Adam N pfm Member
  19. Adam N
    Adam N pfm Member
    Here are a few quick photos for size comparison. Next to it on the right is my latest project which is the same size as the Royd Minstrel.
    orangeart likes this.
  20. Adam N
    Adam N pfm Member
