I have a fitted fridge in the kitchen. Yes, I know, but it came with the place. It's Bosch branded, fridge freezer, right hand hinges. The hinges on the fridge played up 2 years ago, you get a cracking sound on occasion and the door won't stay shut. Fixed that with new hinges. Fine for 2 years, so the new hinges are doing their job. I've noticed recently that the door now appears to be twisted so I have taken the trim off and sure enough the thing seals on 3 corners but not bottom left, away from the hinge. I can't see an adjustment for this, you need a decent push to make the door fit, it then springs back. I've had this before with conventional fridges and not been able to fix it. Has anyone got any top tips for hinge adjustment in these circumstances or is this the beginning of the end?
