Finally completed the new DAC based largely on boards from TPA. Specs are:
Input: SPDIF (Coax, BNC and optical) and USB
Main DAC: ESS9038PRO (TPA BIISSEPRO)
Power: 2x100VA torroids for digital and analogue sections, one 20VA torroid for the Arduino Due.
Current to Voltage Conversion: TPA Mercury
USB Conversion: Amanero + Isolation + Reclocking
Analogue Out: SE and balanced
Control: Arduino Due (inputs, dac options, display dimming), controlled via Apple remote
Display: LCD
Case: HiFi2000 with custom front and rear panels from Front Panel Express
Control switches options on the DAC and the input switch board. I originally was planning to address the DAC directly but opted to instead switch via the switching available on the DAC board. The only real disadvantage I see is that I can't display the sample frequency.
Code for the Arduino was written from scratch (having never written C++ code and only having coded eons ago in Basic it was a challenge!)
How does it sound? Very nice, a definite step up from the older ES9018 that it replaced.
P1200423.jpg by Martin Carrington, on Flickr
P1200426.jpg by Martin Carrington, on Flickr
P1200424.jpg by Martin Carrington, on Flickr
Display: LCD
