sam_cat
C'est Crounchifique!
Elegant solution.
I know its too late now, but for anyone else looking/ideas I will post anyway...
When I went external WC (pair of Monsta 480 rads in push-pull) I used one of these to pass the Molex power and fan PWM externally via PCI slot plate, works very well.
https://www.watercoolinguk.co.uk/p/...Pin-Molex-and-3x-4Pin-PWM-fan-plug_76349.html
And then one of these to split a single 4pin fan connector to all the fans:
https://www.watercoolinguk.co.uk/p/Phobya-4Pin-Molex-to-9x-3Pin-Fan-Splitter-PCB_58527.html
If going further away I considered running a separate PSU switched on by the molex power using a 24pin-4pin relay:
https://www.amazon.co.uk/dp/B095S58888/?tag=pinkfishmedia-21
Learn to solder/heatshrink and you can make the cable lengths whatever you need.
Used one of these plates to take the water from inside to outside the case:
https://www.watercoolinguk.co.uk/p/Watercool-PCI-slot-with-2x-2-G1--4-IG_68751.html
And a pair of quick disconnects to save having to drain every time i needed to fiddle:
https://www.watercoolinguk.co.uk/p/...Disconnect-Male--Female-Set-Silver_72682.html
PC looked like this:
But this is me now... Baby on the way and all the cabling/hoses/fans seemed a bit 'at risk' so went back to it all in a big box (719)... its huge, and stuffed full!
Hottest day of the year (38c ambient where the pc is), playing Fortnite as a family we get this (5900x, 3090ti, both overclocked).
