garyi
leave blank
I posted this on the general forum but perhaps DIY guys might have some ideas.
I have created a waterloop for my pc with all the gubbins, fans, pump etc outside of the shed. The water side of things has been a great success and cooling is way above my expectation.
But the electrical side has been hit and miss. It is because the fan headers etc usually associated with the inside of a PC are just so fragile, they just arnt up to the task, I am getting constant issues with wrong DC readings or total loss of power etc. Also I want a solution for pluging and unplugging. If I ever need to do mantainance on the PC I want to be able to take it out, so want a solution of connecting up the external fans so as to be disconectable!
My first attempt an big brain was to go ethernet. It can carry more than the electric I will use but because ultimatley its having to be soldered to the shitty fragile fan connectors it went wrong.
Well anyway what I need is some solutions for 4 way connections. At the moment I am looking at din. But I will need a lot of connections. it is my intention to replace all the fan connectors, I want a a better solution that stock. But I also feel a din plug on each fan is overkill. But I just dont know search terms to go looking.
Any help please! I guess the simple question in connection solution for low power 4 way.
