puddlesplasher
As a very long time user of Exposure amplifiers I have always used cable talk interconnects but curious as what others use with their setup and with what results.
This is because Exp amps are not "unconditionally stable" rather like amps from Naim and (iirc) NVA. This can cause the amp to go into oscillation which causes internal damage to output transistors. This is the result of the amps not having a Thiele network on the output, so they rely on the inductance and resistance of long speaker cables to provide this.I don’t think it’s important what interconnects you use, so try a few, but I do believe you have to careful with Exposure amps when choosing speaker cable. Others will understand the technical reasons why.
To my knowledge the early Farlowe amps only, were sensitive to speakercable lenght.
Such as X, XV, IV etc.
2010, 3010 etc. are later non-Farlowe design
Think I read somewhere way back it was a basic cable talk cable. We'll voiced for John's amps.Wasn't the Brown i/c a Cable Talk ?
