Ever heard decent on wall speakers?
Discussion in 'audio' started by indus, Oct 11, 2019.
  1. indus
    indus pfm Member
    I'm trying to get some kit together for a second system. It's to go in a study/library where floor space is at a premium. Wall mounted speakers would be ideal.
    Any suggestions welcome.
    Musicraft likes this.
  2. Darren L
    Darren L pfm Member
    I used a pair of Rega Kyte speakers on wall brackets many years ago. Excellent. I'm not sure what the modern equivalent would be.
  3. mandryka
    mandryka pfm Member
    If you have the budget why not audition a Sonus Faber Sonetto?
    I have wall mounted a pair of Warfdale Diamonds with some Linn Brakits, which allows a few inches of space between the speaker and the wall, and allows the speakers to be oriented as you wish. The brackets are completely invisible. I just use it for listening on my office computer. Whether wall speakers can ever sound better than that I just don’t know. I bet to make them sound better you’ll need to put a sub somewhere.
    The other thought is to buy a pair of Rogers JR 149s and get the special brackets for them. I used to do this. For treble and midrange I would be surprised if you could do better. Bass is always going to be a problem!
  4. Amber Audio
    Amber Audio Trade: Amber Audio
    Flush fit or on brackets?
    Budget?
    Have MA on walls and ceiling speakers - Gold series spendy but decent
    Dali on walls are good
    Had a Qute to Rega RS1 on their brackets which worked really well, they are older models, new one is RX1
    Gus
  5. simon g
    simon g Taking a break from forum
    Spendor SR5
  6. Hoopsontoast
    Hoopsontoast pfm Member
    Used both the Rega R1 and Keesonic Kolt up against a rear wall, the Kolts were the best, not supprised as that's what they were designed for but not easily available.
    The ATC Hts7 look good, I tried the SCM7 up against a rear wall bug they do need some space, the HTS version look ideal as they are specifically designed for it.
    The Proac Tablette 10 seem to be suitable although I've not actually heard a pair yet.
  7. uncl_nigel
    uncl_nigel pfm Member
    Jern had a very convincing on-wall speaker at Munich this year.
  8. AndyU
    AndyU pfm Member
  9. h.g.
    h.g. pfm Member
    There have been a few posts recently asking about wall mounted speakers. "Proper" high-fidelity speakers designed to function correctly when mounted on a wall are pretty rare because of the need to control the strong reflection off the front wall which conventional speakers don't do. Do you have an interest in DIY speakers?
  10. jobseeker
    jobseeker pfm Member
    PMC Wafer 1 and 2 aren’t cheap, especially the larger and superior Wafer 2. They’re good though and occasionally found ex dem. They dig pretty deep too. Gato Audio make some nifty wall mounts that can be found at a good price ex dem.
    AndyU likes this.
  11. Goldenmouse
    Goldenmouse pfm Member
  12. Taff63
    Taff63 pfm Member
    Mate has the Wafer 2s with a B&W sub. Not really that impressed tbh - clarity isn't bad but dynamics and extension not great. That said they look good and are unobtrusive.
  13. Electrostat
    Electrostat Active Member
    One of my partners has on wall Maggies in his HT, they sound quite good. Though you do miss out on that depth of image and sounds are more projected forward in a 2D plane.
  14. Musicraft
    Musicraft Trade: Musicraft
  15. colasblue
    colasblue pfm Member
    Both Kans and PMC wafers are pretty good in slightly different ways provided your actual listening space is reasonably sized and you're a good few feet away
    How big is the space they're going in?
    If it's basically speakers around a desk I'd choose neither. What would be way better is something like a pair of Genelec 1029a's or 8020's on wall mounts since they're specifically designed to work like that (ie professional near-field monitors). If you add a sub they also work pretty well in a bigger space as a satellite and sub system.
  16. jobseeker
    I can only say that I have them and I disagree, but then I would wouldn’t I :)
  17. Yank
    Yank Bulbous Also Tapered
    Duntech PCL-3 were made for hanging on the wall.
  18. AKG
    AKG pfm Member
  19. h.g.
    h.g. pfm Member
    Looks an interesting product. Would be useful to know how it performs and what has been traded to get the on wall package. Probably the biggest downside of a nonfunctional home audio press is not getting a handle on which consumer products have a good technical performance and which do not.
  20. cctaylor
    cctaylor pfm Member
    One thing to consider is how close you will be to speakers. You need to be able to angle them towards you. A dry run in the proposed position is advisable. I had Videoton Minimax speakers in my study. They did not work well above head height. They were much better at head height even if I was very close to them.
    Many small bookshelf speakers should work in this situation.
