JTC
PFM Villager...
Last night I tried a different amp than my Nait 2 with the ESLs. Immediately we noticed a definite shift of the sound towards the left hand side, which I think I hadn't noticed before* due to the Nait 2 having a balance control which I've obviously used without thinking. The other amp has no balance control.
On investigating further (swapping cables, speakers etc.) I think one of my ESLs isn't giving much bass output. I'm hesitating to say 'no' bass output, i.e. panels not functioning, as I'd have thought that it would be more obvious. However, up close to the panels I'm not hearing a lot except from the centre (HF) panel.
Anyone know why this might be? I can understand one panel developing a fault, but both at the same time? Could it be a loose wire? Something else? There are no crackles or other odd noises, and the upper portion of the music - i.e. the middle panel - sounds absolutely fine. My limited knowledge of ESLs seems to suggest that it's usually the HF panels that go before anything else.
I'm hoping it's nothing major, given that I don't have boxes and that driving them to Quad would be a hell of an undertaking. BUT, something's not quite right...
* embarrassing that I hadn't noticed, but then I wonder much the brain was able to 'in-fill' from the working speaker after I'd reduced the gain different per side using the Nait 2's balance control...
