Failed miserably as I only managed to make it necessary to remove ten components, twelve hoses, 34 bolts
( mostly in totally inaccessible locations), 16 connectors made impossible to disconnect, a wiring harness wired bar tight to ensure the need of a midget
contortionist auto electrician to repair the broken wires (should you be lucky enough to find the correct connectors).
Practical failed miserably as I only incurred 14 lacerations and lost a mere 3 pints of blood working on the mock up engine.
Air turns Blue often working on my old Ford, the wife's old Astra- decided easier to scrap the crap but my love affair with Honda is/was waning rapidly till I saw the utter insanity my mechanic pal was trying to deal with today on a Peugeot Diesel, mind boggling insanity or French Iunacy?
No wonder they are now called Technicians and if you thought Linn tight was tight, imagine needing the leverage of half a scaffold pole on the socket wrench to remove your spark plugs?
Thinking of going back to cycling!
