Elsdon Wonfor Audio LS-25 speaker cables
Discussion in 'audio' started by Cereal Killer, Jun 28, 2017.
  1. ABCaudio
    ABCaudio Trade: ABCaudio, representing EWA
    LS-25 and prices are on the website (ABCaudio), and LS-40 will be shortly when we get a few final things costed. As far as I remember, only one of the posters here has a five meter set to trade in, but we'll see what turns up. It'll be absolutely fine with Naim, BTW.
    Not quite based on Tellurium Q I'm afraid. EWA is more of a third generation design by comparison according to Colin, based on original concepts he came up prior to TQ. LS-25 is a similar form factor to the ultra series, but other than that they don't really compare.
  2. ex brickie
    ex brickie pfm Member
    I upgraded from Ultra Black (V1) to LS25 and since then haven’t even thought any more about cables.
    Enough said.....
    GavinB likes this.
  3. radamel
    radamel Music Fiend
    I upgraded from TQ Black and it is settled for me also. No longer a factor to consider.
    GavinB likes this.
  4. 9designs
    9designs pfm Member
    As I understood it, Colin did the original TQ designs, they parted ways and TQ fiddled with it and spun off Foo variants. Where as Colin continued his research above and beyond, which we see in the EWA range.
    CJ14, radamel, ABCaudio and 1 other person like this.
  5. Cereal Killer
    Cereal Killer 432 Point5
    I think that sums up the status quo rather well.
    CJ14 and ABCaudio like this.
  6. myles
    myles Intentionally left blank
    I've got a set of LS-V on their way - quite looking forward to pitching them against the Van Damme.
    Tarzan and ABCaudio like this.
  7. ABCaudio
    I hope you enjoy it! LS-5 is great for bookshelf speakers especially, and runs nicely under carpets.
    Tarzan and myles like this.
  8. Olsen
    Olsen pfm Member
    I'd consider moving my kit around if 3.5-4 mtr is better available
    ABCaudio likes this.
  9. Tarzan
    Tarzan pfm Member
    Why is this please Sir?:)
  10. 9designs
    9designs pfm Member
    LS5 bi-wire vs LS25 single, how would that compare ?
  11. ABCaudio
    Hi. :)
    LS-5 has just half the conductors that LS-25 has, and the inductive shielding isn't as strong. I think it was originally conceived as a proof of concept cable, but sounded really good and it became a product.
    We later twined it in a braided sleeve, before LS-25 was available, and it made a really good product with excellent SQ and bass - but it was no longer flat and compact.
    As above, all EWA loudspeaker cables are better twinned into a sleeve where they are held closely together. The properties of the cables couple in proximity and you get something better than running them separately.
    But LS-25 still comfortably outperforms LS-5 and any derivative of it.
    LS-5 is pretty much out of stock now, and we have no immediate plans to manufacture it again. There's hardly any interest in it when LS-25 is available.
    CJ14 and Tarzan like this.
  12. 9designs
    9designs pfm Member
    Thanks for the feedback.... In one room I use bi-wire/Amp LS25, replaced TQ Ultra Black :D.... That is only a 2 meter run.
    In another room I'm looking to replace my basic Van Damme cable. But at 7 meters a speaker the idea of double runs gets a bit eye watering on cost. Maybe a single run of LS40 and stay single wired/amp'd.
  13. Olsen
    Olsen pfm Member
    Biwire is a con
  14. Cereal Killer
    Agreed, and anything above 12AWG is pointless to an extent it can become detrimental.
  15. CJ14
    CJ14 Retired
    A experiment, NOT TO BE DONE AT HOME BOYS AND GIRLS
    I got some of the EWA IC cable which has four conductors and a shield,
    Tested the break down voltage at 2500VAC between all.
    OK the wire could handle about 3Amps max.
    Made a simple cheap and nasty MK plug and Bulgin IEC lead 2 M long.
    And tried it on the New Oberon I have, based on the M50 and M50P mixed (only 3 ever made cost to high)
    We have one my sons Sam and Scott have one each.
    It was fantastic the cheapo Woolworth IEC was crap in conclusion.
    Just a fun and dangerous things to do under lockdown.
    Still waiting for Solar Panel from space Mike, phew
    Keep well all.
  16. johnacurtis
    johnacurtis pfm Member
    Can say that EWA LS20 is superb speaker cable too. Believe it was 2 x the LS5 run together. Far, far better than the TQ Black I had before.
  17. ABCaudio
  18. steveinspain
    steveinspain pfm Member
    Yup, still very interested, happy to be way down the queue as things are changing in my system....
  19. GavinB
    GavinB pfm Member
    3m not quite long enough for me but 4m would be great!
  20. jan tomczak
    jan tomczak pfm Member
    I will be re-decorating (in the new year) and moving things around so even if i really like them i would not be sure of the length i would require.
    But happy to accept a trial as and when they might come my way, thanks.
