cj66
We have two electric shower units with exactly the same problem but I'm lost on diagnosing the fault(s) i.e. cold water and no power light. One is a Sharp, the other a Mex.
Tried so far;
>Checked gauze filters.....clear.
>Set to low temp., lower head and turn unit on & off min. of ten times, then raise head, use high temp and turn on again.....no change.
>Runs same water flow with or without head.
>ECB switch running correctly.
>Power is reaching unit.
>Water pressure is good.
WITH POWER DISCONNECTED;
TCO has continuity.
Heater reads 18ohms across terminals.
There remains the the water flow sensor to be tested but I don't know how you do that. Any of our clever bods here have more ideas?
(Wasn't sure whether to put this post here or in DIY)
Tried so far;
TCO has continuity.
