Given the move to electric cars and therefore domestic charging points I'd like to share with you what might be a potential problem for the future. My neighbour has bought a hybrid vehicle and told me that because we share the same incoming mains infrastructure that there might be some work required to install the charging point. I'd get written confirmation of what was to be done. Fair enough. The charging point went in but I didn't get any notification of what had been done (if anything). OK.
I have a power regenerator that has incoming voltage reading which is normally rock steady @ 230V. Now when the car is charging the voltage can bounce around between 218 and 230V although I need to gather a bit more data on this. 216V is the nominal minimum limit.
My first question is that if you are running a current hungry amp is there going to be a problem running it at the bottom the voltage range? I would expect 220V to be fine but what happens if it goes down to 216 or less? I have passed this onto Northern Powergrid for comment as it's up to them to ensure the correct voltage is supplied on the mains.
It begs a follow up question. Can our electrical infrastructure handle the the move to electrical cars without it causing long term problems for hifi enthusiasts with power hungry kit? Should we be looking at running our power amps off batteries? Is this even possible? I seem to remember a manufacturer bringing their own electrical supply to hifi shows but this was a huge and expensive bit of kit. Wonder if it can be done now with the current battery technology?
