Does the car dealer have a list of recommended installers ? Having said that I know of 2 people who did not buy an EV this time around due to the whole house needing re wiring before a charging point could be installed.
Is this not something which can be done by one's electrician? If an ordinary 13 amp socket, surely, a radial to your existing c.u. would suffice if the domestic circuits are fully functional and compliant, assuming spare c.u. capacity.
Not sure if a dedicated EV supply is within the remit of a registered electrician, though I don't see why this shouldn't be so.
My meter and main fuse are both 100 amp, so I guess this is sufficient for any EV charging unit.
I wouldn’t want to be taking even 3kWh for more than 10 hours (for a half charge) from an extension cable plugged into a 13 amp socket several metres away.
I'm assuming the best charging points for home vehicles are sort of battery packs which can store and charge the car faster than the normal limits from domestic supply, and so give you a home 'super charger' which, say, charges overnight on cheap electricity, and then allows you to top up your car when you get home. Is this how things work?
There are home battery systems - Tesla PowerWall is one - that use off peak energy and maybe if you have solar/wind gen at home they can help you manage power and therefore charging but not at supercharger levels. 99% of people don't need this, you just charge at nighttime when the car is parked anyway so you don't need fast charging and the chargers can be set to only charge at certain times.
Much as with an immersion heater i guess, you can either use a flash plug saying immersion heater or car charger on the front or a Tesco time switch; three for a tenner last time i got some.
but a dedicated spur should be fine.
Radial? Spurs can't be dedicated in the electrical sense and probably not a good idea for an EV socket, I'd've thought.
Whatever the word for a single wire from the distribution board with a socket on the end of it is.
To the rewiring question, in the UK the installer will connect a new breaker box to the incoming mains (post meter of course) creating its own 32A circuit that completely bypasses the house wiring system
That's a new one. Where does the breaker box actually sit? Would it be on the tails from the meter before they enter into the consumer unit in the external meter box?
Curious.
