Ebay audio kits - opinions
Discussion in 'd.i.y.' started by df_genius, Sep 12, 2015.
  1. df_genius
    df_genius Solder slinger
    The SOA chart for the MLJ3281/1302 looks similar to the 2SC5200/A1943, so I would stay under 50V rails and make sure the heatsinks are big.
    I fired one channel up today on 28V rails and it worked OK, the DC offset does drift alot at startup but the built-in protection circuit comes in at around +/-600mV.
    I've read on DIY Audio that it has low PSRR so a regulated supply might work well, I am thinking about using a low drop out LT1083
  2. PigletsDad
    PigletsDad pfm Member
    I would expect the main cause of the PSRR will be in the early stages, which only need low current, while teh output devices won't matter so much. So simply adding a second small rectifier bridge and pair of modest caps to power everything except the output pair may give many of the benefits of regulation at modest cost.
  3. df_genius
  4. Tony L
    Tony L Administrator
    Worth the price of admission just for the Chinese to English description!
  5. Tenson
    Tenson Trade: AudioSmile
    I know it may seem boring but if I were to buy an amp PCB from eBay I'd get something TDA7293 based. I believe a number of these ICs were used in parallel in a Mark Levinson power house and also in some Linn amps.
    This for example - http://rover.ebay.com/rover/1/710-5...0001&campid=5338728743&icep_item=131605699788
    The trouble with eBay kits is that I doubt they refine the designs. They probably just make sure it produces sound with no horrible buzzing noises then ship. A good design will be measured and tweaked for ideal grounding and stability.
  6. df_genius
    I've bought the A1 kit just to see if it works.
    If you're building your first discrete amplifier I don't think you can wrong with these, I've not seen any dodgy parts in any of the LJM kits I've bought, they work fine and are reputed to sound very good. I have a pair and they work fine, they could drive my 5 ohm dummy load to 100W before clipping on 32V rails, I've not done extended listening yet as the FAST amplifier I am making with them isn't finished yet.
    http://rover.ebay.com/rover/1/710-5...0001&campid=5338728743&icep_item=221357376090
    The designer LJM frequents DIYAudio and his designs seem to stack up to scrutiny reasonably well.
  7. firestorm
    firestorm pfm Member
    Any one with updates to their Ebay/aliexpress/banggood source amplifiers in the last 6 years?
    One thing I've seen that has caught my eye is the use of point-to-point wiring or "scaffolding" with chip amps, not sure what advantages it confers, but it looks different.
    I don't think it's a good idea to mount electrolytic capacitors onto a hot heatsink...
    [​IMG] [​IMG]
  8. slavedata
    slavedata pfm Member
