Rug Doc
I have a valve amp that I would like to use occasionally, I would like to have the cables in place and be able to switch the speaker cables behind the speakers when I want to listen..
I understand that if the amp is powered on with the cables inadvertently disconnected it might damage the output stage, so can I put a resistor across the cables permantly so when disconnected there's still a load on the amp? Would doing this effect the loading of the amp enough to effect SQ and be audible?
