foxwelljsly
Me too, I ate one sour too.
All,
Anyone used one of these? If so, how easy are they to set up?
I have 2 ADSL circuits with 2-5 MBit/s each and figured I could devise a home network using a Dual WAN Load Balancing Router and some stuff I have knocking around to split LAN clients over over both DSL WAN circuits and use a single LAN instead of two as I do currently.
Plan is to use a netgear VDSL modem on one circuit and a BT Homehub as a modem on the other, run both WAN links into the load balancing router to allow the LB router to manage the LAN and LAN DNS and connect a gigabit switch and WAP for LAN connectivity.
I'll also be connecting a powerline network in to extend connectivity to the kitchen and living room.
Any thoughts?
cheers
Any thoughts?
cheers
