I have a dedicated(20a) radial coming from the first upgraded breaker in the consumer unit. I also have a dedicated earth. I felt it made a difference. Last Christmas with time on my hands I plugged an extension into the hall and daisy chained a four gang into it. Plugged the system into that. I really couldn't tell if there was a difference or not. I do live in a very rural area, no heavy power users for over 20 miles and no axe to grind. But there you go.
Well, at least you're open-minded enough to test it and then accept the evidence even though the result might not have been what you hoped.
Do you use Naim kit? I get the impression that the most satisfactory results with dedicated hifi circuits are gained by Naim users?
Anyway, your negative result is in fact a positive one really as it suggests that the mains is not interfering with your listening pleasure...
Junk
