TheDecameron
Unicorns fart glitter.
I remember hearing a Theta for the first time in the early 90s and it was head and shoulders above other stuff at the time. Has the field closed now?
If these DACs are all designed to a common and complete set of requirements specifications, and if the implementation is competent, then indeed they will sound very similar.
If there are any obvious and blatant audible differences then one or more of the requirements have been violated, or the design was not done well.
And there in lies the problem. Like just about any other piece of electronics, DACs are build to a price point and to achieve that price invariably corners are cut. Cheaper parts get sourced and invariably they affect the sound.
Everything always sounds the same, the only differences that exist are our imaginations and the words we use to describe what we imagine and how much we are prepared to pay for having an vivid imagination.
Totally agree, well said.I wouldn't quite go as far as to say "everything", but agree with the rest of the quote above. As far as DACs go, I class them together with all modern competent electronics, in that perceived differences disappear on level-matched blind testing unless the design is deliberately done in such a way as not to be transparent.
As Robert said above, if a designer wants to be different and stand out on demos as being different, that's fine as long as it's clearly understood that they are doing something different, not necessarily better and certainly less accurate.
S.
Seems difficult to argue with although I guess it depends what the complete specification is.If these DACs are all designed to a common and complete set of requirements specifications, and if the implementation is competent, then indeed they will sound very similar.
