DIY Tube amps - where to start?
jamesd
For fun I’m interested in trying to dip my toes into DIY tube amps and preamps. I know very little about them and my understanding of electrical circuits is minimal, but I can use a soldering iron and am somewhat handy.
is this a stupid endeavor? Could I possibly put something together that would rival an off the shelf unit like Line Magnetic, Rogue, etc?
if it’s not a completely stupid endeavor, what’s a good spot to start reading/learning? I see that a bunch of books on the topic exist.
Any thoughts are welcomed and appreciated
The actual physical assembly is not the hard part, there is a lot of hard won / hidden knowledge that people just won't share with you.
My strong recommendation for a pre-amp would be the John Broskie CCDA and if you prefer a pre with no amplification then go with his Aikido pre.
https://glass-ware.stores.yahoo.net/ailiam.html
https://www.tubecad.com/2009/03/blog0161.htm
https://www.transcendentsound.com/son-of-beast.html
for a power amp go with the Transcendent 'Son of Beast' - the sweet spot of the range.
only use a TKD pot
only use a TKD pot
thanks!
apologies if this is a stupid question: when referring to a point to point wired tube amp, where does the hidden knowledge lie? It appears like they would be fairly simple to reverse engineer?
Circuit layout is an art in itself. Typically 'bottle amps' have a higher input and output impedance and things like stray capacitance, cross-talk, hum pick-up etc. due to poor circuit layout become more critical. Even more so if you are driving high-efficiency horns with just a few watts!
