Sid and Coke
and so the rebuild continues..
Not too sure whether i should have posted this Q in Off Topic . or DIY but here goes:
My Mana wall shelf used to live flat against an internal wall making installation fairly easy. I am in the process of moving the Hi-Fi Rack from this location to a corner location. I (we ) have decided that my Hi-Fi looks far better sitting accross the corner, rather than flat against one wall or the other. This set-up is also more practical for installing/changing cables etc, and will give a little bit of space behind the Hi-Fi to 'dump' irregularly used stuff out of sight, but still to hand.
My actual set up will consist of 1x Mana sound stage, 1 x Mana 4 tier Rack, 1 x Mana wallshelf, 1 x Mana reference top. There are several ways i can go about installing this little lot.
Option # 1 (which is my intended option)
Sound stage on the floor with Amp rack on top. Reference wall shelf mounted onto the wall above the Amp rack with just enough space to place a component between the top of the amp rack and underneath the wallshelf, probably my Pre-Amp.
I am one of a seemngly dying breed who actually still like the look and build of their Mana so rather than using this thread to discuss the merits or de-merits of Mana equipment racks and better alternative options....
The only way that i can think of doing it at the moment is to Mount a couple of fairly hefty wooden battens flat against each wall, with a 45 degree angle cut into the side of each, then mount my wallshelf onto these 45 degree flats sort of like this Here ( apologies in advance for my MS Paint effort )
So, question: Has anybody mounted a wall shelf in a corner, across the corner and how did you go about doing it.
One of the walls is an external wall the other is an internal stud wall, both of which are plasterboard over whatever is underneath.
