I was thinking the same thing, maybe Mr Disbeliever should do a bit of Goggling and get his facts right first.
What truth - It's just your opinion. You didn't like it before you'd heard it. Then you tried one and still didn't like it. I tried one, liked it and bought one and really enjoy what it does. I really don't understand why you spend so much time on this personal crusade across a number of forums.
Very strange.
indeed. As I understand it the tech they have deployed is similar to that in the NCore nc400 modules which has a rep for Class A performance (which is my preference over most AB) but Class D heat levels.
I've listened yesterday the D1 with Harbeth 30.1. What i heard didn't impress a lot... the sound is clean but lifeless and also "shut in". The highs are not really accurate ( instrument like saxophone sound "edgy").
The seller replace replace D1 by MDAC+LFD PA2M power amp and the music came back. This combo put a smile on your face... i've bought the M30.1 and in the future i think i will buy LFD amp... it's so much better
It seems the new D170 is really better that the D1 but i've some doubts... I will try when the dealer will receive it
indeed. Are you familiar with the tech deployed in the nc400 modules?Hi Greg, the technology has been explained on the web in more depth than most others I have seen, including a white paper they published themselves.
Google is your friend - no need for wild speculation!
It isn't like any other, possibly most like quad current dumping in concept though completely different in excecution.
They run quite hot, >50C, since they are effectively class A amps with some clever technology running in parallel.
Is there a list of UK dealers anywhere?
I have found a couple of companies advertising down South but nothing anywhere near me in Cheshire.
Hmm. Reading Werners description of this tech, it tallied closely with what I read about the NCore tech, I must have misinterpreted.Greg the Ncores and the DVLA are nothing like each other in tech. Sure they both use the magic ''class d word, but the implementations are about as far apart as is technically possible.
I also ordered in July. I'm hopeful of arrival by the end of September.If anyone is interested there is currently a lengthy backlog of orders for the 170. I've been waiting for over 6 weeks with no eta currently
I could never get my unit ( only one) even warm to the touch, that was using the 98dB Cessaro Alphas.
Keith.
hahaHumility is not allowed in the audio room.
I'm ready to believe a lot of things, but 108 dB from the Animas (which I like)? No way.
