George J
Herefordshire member
Derating the power of a valve amp?
Is this possible? Would it result in longer output valve service-life? Would it make the actual quality of sound worse, or even possibly better? Would it reduce the risks other than to the valves?
The amp I have in mind is my Quad II Forty, which is nominally [if not actually according to some reports] a 40 watt amp.
More than obviously this will only be considered after the current times pass and we return to normal, assuming I still have a job and so on.
The Q II forty has two KT 88s on the output side, and I find it a rather fine amp on my ESL, but if I could get longer service out of it, that would be good, and certainly the ESL needs less power than the amp can deliver in stock form. I never play loud, so if there were real service life gains, hopefully without reduced quality, I would happily go ahead one day. I would happily live with 20 watts ...
Keep safe and best wishes from George
