Dead Hard Drive; Help!
Discussion in 'off topic' started by doctorf, Jul 18, 2018.
  1. doctorf
    doctorf left footed right winger
    I would be very grateful for advice.
    I shall be brief;
    Returned from holiday to find my 3TB Seagate Sata drive was not showing up on my pc (windows 10)
    Drive C is an SSD and works fine so boots up etc.
    My backups may be usable although my Outlook PST files may not be backed up properly.
    I have ordered a new 4TB drive to arrive today and of course the easiest option would be to recover the data on my old drive.
    I have opened the drive and it looks fine. The heads are not stuck on the disc.
    On firing up it spins but then I get a crunching noise and it stops.
    I am happy to continue life without Outlook and just use backups to restore all my docs and programs but any advice re data recovery would be useful, although I really do not want to spend hundreds of pounds for the pleasure.
    Any suggestions??
  2. Mark Grant
    Mark Grant Trade: Mark Grant Cables
    Annoying when that happens.
    Install the new drive and start recovering what you can from backups.
    Segate do a recovery service, it is expensive https://www.seagate.com/gb/en/services-software/recover/in-lab-recovery/
    Although you opened up the faulty drive, rarely a good idea.
    When you do get a working system look at your backup method so you don't get caught out again.
    Backblaze is wonderful for this. https://www.backblaze.com/
    The latest version of your outlook pst would have been on backblaze for download if you had it installed.
    Good luck !
  3. zippy
    zippy pfm Member
    "On firing up it spins but then I get a crunching noise and it stops."
    Doesn't sound to me as if there's much hope for that disc even being readable, let alone having data that is recoverable.
    "I have opened the drive and it looks fine"
    I've worked as a PC technician for years and there's no way I could tell the state of a drive by looking at it.:)
    You've kind of lost some options by opening up the disc - I doubt any recovery service would touch it now though worth a try if you have the cash.
    Should we assume you have no external backup? If you have there's no real problem other than the time involved.
    Mr Cat likes this.
  4. Derek Wright
    Derek Wright pfm Member
  5. formbypc
    formbypc pfm Member
    Did you open up the drive in a clean room? With filtered air?
    If not, I wouldn't hold out too much hope for anything.
  6. gintonic
    yep we use a clean room for this. If the drive wasn't entirely knackered before the OP opened it - it will be now!
    Mr Cat likes this.
  7. doctorf
    Thanks for all your replies.
    Thanks a lot. I'll have a look.
    It's archive.pst which will not back up so not the end of the world.
    I do have external backups of everything apart from the archive.pst outlook file.
    Thanks a lot. £300+ isn't worth it for me.
    I didn't & I don't!
