Hi all,
I hear an occasional hum/buzz from the transformer in my Meridian 557. It isn't constant, only perodical, and so I have deduced that some sort of floating DC on the mains is to blame. At the same time, I can hear a hum from the amplifier of a subwoofer located in a different room of the house.
this filter seems to fit the bill perfectly, however it's only rated for 1.2kva where my Meridian supposedly sports a 1.6kva transformer.
Will this be a problem considering I'm never likely to draw anywhere near enough peak current, or are transients likely to reach this?
If yes, has anyone found any comparable filters that can handle more current? I seemingly can't find anything else online that isn't a 'consumer' mains filter costing a few hundred, or mains leads costing thousands (!!)
Thank you
Thank you
