DACS with less than 2V output gain?
Discussion in 'audio' started by eastone, Apr 7, 2021.
  1. k90tour
    k90tour pfm Member
    Sorry to interrupt this thread.
  2. Vinny
    Vinny pfm Member
    Not simply :)
    I had always asssumed that they were just resistors, but they aren't. I looked them up on good ol' Wiki and all was revealed - they are simple, but not that simple, but there are different designs/principles.
    This was flagged-up to me a while ago here, as someone actually had their attenuators the wrong way round. I am pretty sure Jez sussed what was up.
    Because they (usually) have a male RCA one end and female the other, they are meant to be fitted at one end or the other of an IC - changing the end, changes their "polarity". So far as I am aware, both types are available.
  3. k90tour
    k90tour pfm Member
    Ah. Ok. I think I'm on the right track. I was wondering if the resistors themselves are directional. I believe they become so once burned in. I'm just hooking up a 1-setting only attenuator without a switch involved. Just a pure voltage divider.
  4. k90tour
    k90tour pfm Member
    I had an Audio Note DAC with a 3.0V output , which was too much. They sent me a wiring diagram so that I could change a resistor near the RCA sockets.
    eastone likes this.
  5. eastone
    eastone pfm Member
    I’m going to try the Calyx Coffee that Fergus kindly offered. 1.3V from the headphone out - should do nicely. :)
  6. Yank
    Yank Bulbous Also Tapered
    It's not so much that they're "directional" as the attenuator circuit has an input side and an output side, even with just two resistors.
    miktec and martin clark like this.
  7. martin clark
    martin clark pinko bodger
    ^1 exactly that.
    Used the 'wrong way round' does not provide any attenuation, it just loads down the source a bit (which it should shrug-off) and adds a little series impedance.
    So such passive attentuators are 'directional' only in the sense that used correctly, reduces signal amplitude on the output; used incorrectly, they wont!
    Agree - not necessarily intuitive as a black box which is wholly passive and inherently 'linear',; but a nice little logic puzzle.
  8. ALFY
    ALFY pfm Member
    Yes as mentioned
    Qutest
    Chord Qutest can be set to 1V
    k90tour likes this.
