Hi, I have a Chord Qutest DAC and can select from 3 output options - 1v, 2v, and 3v.
My Jadis amp has input sensitivity of 250 mv.
Might be a stupid question but what output should I select on the DAC? And what difference might it make?
Thanks!
I beg to differ- taking Naim super nait as example the input sensitivity is 175mv but they don’t overload until 7v. Most amps are circa 300-500 mv these days. But I do agree that having more range on the vol control is betterThe rated sensitivity of an amp is the level of input at which the amplifier produces maximum output without clipping. 250mV is lower than many amps, (1V is more usual), so I’d try 1V which still may be too much. Play something loud and listen. Clipping sounds pretty grim. Have your hand near the volume control because some kinds of clipping can damage your tweeters. You can always attenuate in the digital domain if you have to, or use an analogue attenuator.
